la feuille est assez grande pour en faire 2 alors si quelqu'un d'autre serait intéressé on pourrais splitter le coût de la feuille en 2.
c'est 111$ + tx c'est un fournisseur de l'entreprise où je travailles. donc ca reviens environ à 60-65$ chaque.
Idéal pour un petit DIY pas cher pour passer le temps cet hiver.
un front splitter c'est ca (sauf que celui ci coute 300-400$):
et ca sert à ca :
SplittersAs the front of the car slows down the air without a diffuser, this is the ideal place for an inlet. A splitter is commonly used here, serving to increase the amount of downforce at the front of the car. The airstream is brought to stagnation above the splitter by an air dam, causing an area of high pressure. Below the splitter, the air is redirected away from the stagnation zone and is accelerated, causing the pressure to drop. This, combined with the high pressure over the splitter creates downforce. The larger the area of the splitter, the more downforce is generated. In most closed-wheel race cars, the underside of the splitter smoothly integrates with the undertray, creating one large flat plane that is driven by the rear diffuser. Some race cars, such as the Toyota GT-One actually use an additional diffuser immediately behind the splitter to help create more downforce.[5] The air extracted by this diffuser is exhausted through vents in the sidepods or above the car around the cockpit.
moi je vais m'en servir principalement pour caper le dessous du bumper avant vu que les splash guard d'origine ne sont plus utilisable a cause du piping d'intercooler et de toutes mes patentes. Le downforce que ca va générer va juste être un bonus.
